Right cup not producing sound at all.
I have this spare pair of headphones that i want to give to a friend to play online, but I'd like to fix them myself. What do you think could be the most common fix?
Это хороший вопрос?
Это хороший вопрос?
Maybe the cable that connects the two cups is broken - can you disassemble them and check the cable with a multimeter? Or maybe the cable is ok but there is a faulty contact
Был ли этот ответ полезен?
I have the same problem, it was playing normally, then I put it down on table, in 5mins I pick it up and right cup is silent, tried all system settings, restarted, found there is really no sound..
I also suspect, as usual it might be the connection between the two cups, but, I dont see a disassembly guide for that, guess I will just try it somehow.
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 45
2 Комментариев
@davidalva your headphones are the wireless Razer Barracuda X?
из oldturkey03
Yes. the first version without bluetooth.
из David Alva
