Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2375вопросов Показать все
Overheating and battery drain after Fall
Hi,
I have dropped my iPhone 4 last week from my pocket.
The problem is, since that happened, the back section of the iPhone, heats up and gets very hot. The heat is on the right side of the phone (where the rear camera is).
This results in the battery draining VERY fast. With just some casual safari browsing, the battery falls by about 10% - in just 2-3 minutes.
When charging the phone is EXTREMELY hot.
The rear camera, also suffered a shock, and the focus motor does not function any more.
The exterior of the phone stayed perfectly fine, but I fear that there is some sort of short circuiting within the board. (cannot be the battery, as it does not get hot).
Does any body have any idea how to check for short circuiting within the board?
If you have any suggestions please help!
many thanks
Sam
Это хороший вопрос?
Оценка 8
1 Комментарий
HI
I fell asleep yesterday afternoon i woke up and my iphone 4 was on a black screen but the screen was still on then it had died i tried to charge it and was getting EXTREMELY hot and it wont turn on
Many thanks
Dalton
из
Добавить комментарий
17 Ответов
Выбранное решение
just dismantle it . take out the logic board out and put back inside after 30 min. do not screwed any screw inside. and put back all the jacks . then use it for a while and check it still heats up or not
Был ли этот ответ полезен?
Оценка 3
8 Комментариев:
I'm having the same issue. Simian, if it still heats up with all the screws out what does that mean?
из
do one thing remove all the jacks means remove camera , power button , front camera. for checking just put the lcd and touch jack on the logic board not any other and one charging jack and the battery also. then try to power up with usb cable. after powering up remove that also . then use it for a while if still heats up then it looks like your logic board or battery is bad. then try with other battery . still same then last option to repair the logic board.
из
Simran, thank you! Your solution worked.
My iphone 4 started to heat up rapidly, especially on the top right hand corner, near the camera, which resulted in the the battery draining out in few minutes. My phone was out of warranty so I decided to take it apart and reseat everything.
I removed the logic board, removed all the dust inside and reseated all the connections. Some of the screws holding the board to the metal chassis was loose.
It works perfectly now.
из
Hey guys I need help, I have an IPhone 5c I changed my screen (third party) since changing screen my battery on the phone is really bad. I fully charge my phone and few hours usually around 4 hour it just does dies, sometimes I have my wifi and 3G data off and it still eats battery. Also sometimes when I press the home button it skips battery I'm so frustrated because I don't know why it keeps doing that
из
Hi im prasad actually im also facing this problem but actually when my sim card inserting in to my i phobe then its starting heating
из
Показать 3 больше комментариев
Наиболее полезный ответ
I had the same problem
took the phone to be checked and
It was the camera ,, it had to be replaced as it was mucking up the board -
Its fine now
I am a Happy Lady
Оценка 4
3 Комментариев:
where did you take it? to your service carrier or apple dealer?
из
This was my problem too. I took the camera out and it seems to be working fine now. I'll give it a day and then if it's still seemingly good I'll order a new camera.
из
genuine question,how is it a problem in camera? OP has the same exact situation with me as i dropped my 6s plus on the bathroom floor. it has minimal dents on the side but it overheats when im using wifi, bluetooth, or when im on call.
из
Chris, that's correct. The phone can work without the camera.
Оценка 1
my iphone 4 gets really hot when charging , also by battery is draining quickly ???? dont know what the problem is
Оценка 1
1 Комментарий:
First remove all metal cover and wash with IP there some metal protector earth with positive And fit without metal protector the problem will solve
из
Check the battery out, try replacing it but I don't think it could help much... Most probably problems with the logic board. Usually it acts like that after water damage...
Оценка 0
similar problem: overheating as above, and after about a month the logic board died completely. i bought another phone (older and with many signs of wear), swapped the board - same issue. swapped the battery - same issue. seemingly must be some other component. the camera suggestion from Linda gives me some hope - was it the big, rear-facing camera? i will check this. any other suggestions? would love not to test components one by one.
regards
antoni
Оценка 0
Same problem and the resolution for me was :
Reset all settings !!
if this doesn't work change the rear camera !
Zz
Оценка 0
1 Комментарий:
how to reset all setting?
из
i can confirm replacing the camera can rectify it. even after a restore the iphone 4 was running hot (even power button felt hot!) and massive battery drain.
there was a tiny chip on the front screen by power button indicating a fall.
replaced the camera and now the iphone is stable. not hot and no drain
"Everyday's a school day" they say
Оценка 0
Have the same problem in a water damaged iPhone 4S here at the mo battery drain went from 87% to 64 in 45 minutes and phone was not being used was only in lock mode..
Charged battery to 87% again and used battery in another 4s an in 1 hour battery dropped to 79% and that was being used a few minutes on Facebook.
Have taken out camera now and testing again will update on progress
Update
hi all just an up date have tryed everything with this 4s and still really bad battery drain even disconnected every connector on the motherboard and still no help.
i let the phone run out of battery to see would it charge up and it wont it just shows the apple logo for 3 seconds and repeats. tryed battery in another phone and it charged up fine... in all water damage has won this time
Оценка 0
2 Комментариев:
Any solution to fix the motherboad?
из
Check the diods there some leaking
из
In my case Linda was right. I just opened the phone, remove the faulty camera and now the device works like a charm. Until you mention it I haven't notice that the camera can't focus correctly (I almost never used it). I have just ordered the camera replacement, but in the meantime I can live without it. Thanks.
Оценка 0
so it is possible to use the iphone 4s without the camera plugged in?
Оценка 0
hi all,
just wanted to report that it was not the camera.
Is it maybe a battery problem?
The battery has a weird "hole" on the backside, could this be the problem? You see the image within the attached link.
Battery
Оценка 0
Hii
I m using iphone 5s and it suddenly started giving problem
It gets hot and battery drains very fast even if i dont use it.
I had replaced my battery but the problem is still same please help me
Any one plz help me and send me the reply on viral.j.shah85@gmail.com
Оценка 0
I had the same problem and I toked out the camera and the phone works perfect.
Оценка 0
i also the same problem what i do ?
battery changer ?
OR /..
Оценка 0
Оценка 0
i dropped my phone about 3 weeks ago and shattered the screen. when i got it replaced i was told that the motherboard was messed up and so far my screen has been slowly breaking (the touch doesnt work in certain spots). im just curious because my phone has also been heating up and the battery has been draining really fast (today it was at 68 and i had the screen locked for 30 mins and it went down to 30%) i honestly dont think the heating and battery draining is because of the motherboard so i was wondering if anyone could tell me if the camera thing should work?
Оценка 0
Добавьте свой ответ
Sam будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 23
За последние 30 дней: 119
За всё время: 99,647
