Car won’t turn on. Clicking sound no crank or turnover
i have a 2002 honda accord dx and when i try to turn it on it just clicks, no crank/turnover just one clicking sound when you try to turn the car on. This started on Thursday 3/21/24. After looking underneath the hood to listen out where the clicking sound is coming from, it’s coming from the starter.
at first I didn’t have any check engine lights on but based on the videos I took it seems like at some point in time it did come on but then eventually it when off. The 1st day which was Thursday no check engine light but yesterday it seems the light came on and if I recall correctly it’s a possibility it came on prior to me changing the ignition switch and after I changed it I no longer had a check engine light. i checked the battery, tapped on the starter a couple of times, I also tapped on all of the relays under neath the dash, changed the starter relay, tried jumping the car and made sure the fuel pump is engaging (which it is) and none of that has worked. Any help is greatly appreciated.
Это хороший вопрос?
