Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
Replace the thermal grease/paste
There is no guide yet on how to replace the thermal grease/paste.
These Macbooks are now around 4-5 years so it's not a bad idea to replace the thermal paste.
They're not obsolute so there will still be users who can benefit from a guide.
Update (04/01/24)
Update:
So I was able to open the MacBook and disassemble the motherboard with the video.
Since I'm comfortable around electronics (this isn't my first time opening up a MacBook, laptop, or even a smartphone), I did choose to replace the thermal paste on the cpu and gpu.
And honestly, after four years of service... Kind of disappointed about the original paste. Dan said that paste will last longer now due to improvements, but the original paste was crumbly as hell. Furthermore I noticed small blank spots on the cpu and it's heatsink, so not very good spread. The gpu did have a good spread. They definitely were generous with the paste on the gpu, because its surroundings were covered with paste too.
Cleaning wasn't difficult, as I said the paste was in a very crumbly state.
After cleaning I gave the copper plates of the heatsink and the cpu and gpu some time to evaporate the alcohol.
I used Noctua NT-H2 and used the "X" to spread the paste on both cpu and gpu.
The only annoying experience was to place back the motherboard in the case. I needed multiple attempts because there was always some small connector/ribbon cable underneath the motherboard. Ugh! After playing like an octopus for a while, I was able to place the motherboard back and with all connectors/ribbon cables out on top of it.
It's do-able but only for people who have a steady hand and... most of all... lots and lots of patience. Take your time. Take some breaks if you get tired or frustrated because the moment that you attempt to work a bit faster or anything like that... something will go wrong. I 100% guarantee that.
I made only one mistake. The connector cable from the left fan is incredibely fragile due to its L-shape (that's what I think). In trying to get the L-shape cable from underneath the board to the top on the board, I got a small tear in the ribbon cable. This fan no longer works. We learn from our mistakes. Should've taped the connector on top of the fan, I wouldn't had an issue to "fish" for the cable since it can't get trapped underneath the board that way. Already ordered a replacement fan.
The temperatures are amazing though. In idle I went from 60-63° to 46-51°. The one remaining fan is also a lot quieter. I'm not going to claim this huge difference to the new paste though. There was so much built up dust in the MacBook... I was genuinely surprised that the MacBook didn't have much higher temps in idle. Both fans were completly covered up in thick dust, and the outlets on both fans same thing. How it managed to get some kind of airflow through those thick dust is a mystery to me.
Anyway, I am very happy with the result. Yes, I did damage one fan connector, but one can only learn with making mishaps.
Это хороший вопрос?
Счет 6
3 Комментариев
Ah! The lack of wetness issue. The silicon oil is just a carrier for the solids which is doing the job! So yes it is dry, but that’s not the material which is wicking the heat away.
из
My CPU average is 70C at idle and easily hits 100C doing browsing and using ther applications. The fans don't seem to respond sufficently to cool theh processor. The computer is over 5 years old now so I suspect the thermal paste is failing and the fans need a cleaning. I am confident I can repair the laptop and your experience will help me. Thank you for the post.
из
Replace the paste with PTM pad and do a VRM cooling mod. The performance gain is insane and the temps don’t go over 82C with full 50w blast on the gpu and throttle stop limited cpu to 48w + fan speed control to kick in from 50c. The thing now feels like it actually has workstation internals.
This is the tutorial for paste change, just as mentioned by OP, when reassembling, stick as much ribbon cables as possible to the fans and chassy with stickers to save major frustration of fishing out mobile level fragility cables and don’t fully dissasemble the fans since they are glued together, and might lose their hermetic properties.
MBP19 16” Paste change video: https://youtu.be/tBrKXhkfnAE
MBP19 16” VRM cooling mod: https://youtu.be/_Iw_X_N8UsI
Total cost:
20€ and 8h of profanity
Bonus video of my results: https://www.instagram.com/s/aGlnaGxpZ2h0...
из
Добавить комментарий
3 Ответов
Выбранное решение
You are right that there should be a guide, however for the time being, here is a great video.
https://www.youtube.com/watch?v=EGW9RAkl...
I hope this helps.
Был ли этот ответ полезен?
Счет 3
1 Комментарий:
We can’t be dependent on the fantastic iFixit staff to create all of the guides. We also need volunteers to create content as well.
из
Time charges things! In years past the TIM paste was still based on old formulations which tended to break down. Todays TIM is much better! I doubt you’ll need to refresh it to gain enough performance improvement for the amount of work and risk if you’ve not done it a few times before.
I would focus in keeping the fans and heatsink fins clean of dust and debris, as well as dusting off the logic board as well if it’s coated up. I also recommend installing a good thermal monitoring app so you can watch things over time. I find TG Pro is one of the best and it allows you to export the data to a spreadsheet so you can track over days, months or years how your system is doing thermally.
Счет 0
Is it absolutely necessary to go through the long disassembly of the motherboard just to change out the thermal paste? Is it only in the much older versions that one could access the fans and change out the paste easily?
Счет 0
6 Комментариев:
@alanbernst72991 Alan, it really depends on which model you have. Things change over the years, so it's hard to give you a definitive answer without knowing which one you have.
из
I’m very confused by how this msg board works as I don’t see my previous msg, nor the response I kindly received via email about whether it is nessessary to completely remove the motherboard in order to replace the thermal paste on my MacBook Pro 2019 (intel) 16”; that response being it depends on the model which I’d neglected to add.
It is model A2141. 2.3 ghz 8 core i9.
Updated recently to OS Sequioa from Monterey and it’s starts off nearly at 100C but drops after that to below 50C. The insides have never been cleaned so that’s in order, but I’m now concerned about crumbling thermal paste. I certainly don’t feel confident about doing the extensive motherboard removal, but think I could handle it otherwise, as seen in some videos that show fan removals and paste replacement done without motherboard removal.
из
@alanbernst72991 - you buried it within the question which hides it, then as you hadn't stated you had the same model Jerry gave you a generic answer.
OK, getting to your question yes in this series you do need to remove the logic board as the screws which hold it on are threaded from the other side. Take a look at Step 7 in this MacBook Pro 16" 2019 Teardown note the screw standoffs on both heat sinks and the holes in the logic board. Here's a similar system guide MacBook Pro 16" 2021 Heat Sink Replacement
из
Thank you. I hadn’t seen this tear down. It’s very obvious what you point out.
из
I can only say this very clearly. I have a Macbook Pro 15" 2018 2.6Ghz 6-Core i bought new in 2018.
It was working perfectly for the first 4 years then i had to swop the battery but Apple did it on there service battery/keyboard replacement program so that was fine. My Mac was good again for a could of years.
Then around 2023 my Mac began to work super sluggish and very slow and from looking at the Activity Monitor my kernel_task was around 50 to 800% most of the time ? Weird i thought. One way to work on this Mac was to remove the bottom plate and set a external big fan to have extra airflow. Thats sucks.
Anyway i later found out that it can happen that CPU and GPU thermal paste is bad and the battery was again dying and was down to 1% left. Whats going on here. I went to some Mac service specialists and they changed the Thermal paste and a new battery and now my MBP 2018 is back to normal and fast as it was when i bought it.
So i can only say to all those people who says that changing Thermal paste docent
из
Показать ещё 1 комментарий
Добавьте свой ответ
lighscan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 33
За последние 7 дней: 210
За последние 30 дней: 887
За всё время: 13,331
