Ponsel mati total setelah terjatuh ke dalam air
Это хороший вопрос?
Это хороший вопрос?
Ketidaknyamanan tidak ada gunanya jika terjatuh seluruhnya terendam air
Был ли этот ответ полезен?
@tanu98676 you will have to treat it just like any other water damaged device. For now, you must stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The very first step I would take is to disassemble your phone. Use these guides iPhone 6s Repair - iFixit for that. Remove the main board and the lightning connector assembly. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board.
Take a close look at all components and connectors, assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. . Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well. I cannot stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. You do not need to leave the parts to dry for very long. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water.
The importance here is the cleaning. It would of course be best to get it ultrasonically cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now.
After that, reassemble your phone and re-evaluate. Always replace the battery on a water damaged device. It will fail sooner or later because of it. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if it was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
Translation English - Indonesian
@ tanu98676 Anda harus memperlakukannya sama seperti perangkat lain yang rusak karena air. Untuk saat ini, Anda harus berhenti mencoba mengisi daya, menyinkronkan, atau menggunakan ponsel Anda. Hal ini berpotensi memperburuk situasi. Hal ini dapat semakin merusak ponsel Anda.
Langkah pertama yang akan saya ambil adalah membongkar ponsel Anda. Gunakan panduan ini iPhone 6s untuk itu. Lepaskan papan utama dan unit konektor petir. Anda harus melepas semua pelindung EMI. Jika Anda tidak melepaskan pelindungnya, Anda tidak membersihkan papan.
Perhatikan baik-baik semua komponen dan konektor, nilai kerusakannya. Carilah korosi besar, evaluasi pin pada konektor, dll. Lihatlah semua konektor serta ujung kabel. . Setelah kontaminasi kotor dibersihkan, gunakan alkohol isopropil 90%+ dan bersihkan bagian Anda lagi. Untuk pembersihan yang benar, gunakan panduan ini. Ini ditulis untuk Apple iPhone 3G tetapi semua langkah masih relevan dengan perangkat Anda. telepon juga. Saya sangat menekankan pentingnya pembersihan yang baik, jadi lakukanlah berulang kali sambil mengganti alkohol setelah setiap pembersihan.
Jangan gunakan udara bertekanan untuk membersihkan karena dapat mendorong cairan dan partikel korosi ke area yang dapat menimbulkan masalah di kemudian hari. Anda tidak perlu membiarkan bagian-bagian tersebut mengering terlalu lama. Isopropil alkohol dengan konsentrasi lebih tinggi akan cepat menguap dan menghilangkan air.
Yang penting di sini adalah pembersihan. Tentu saja yang terbaik adalah membersihkannya secara ultrasonik. Jangan lupa mengganti baterai. Ini adalah suatu keharusan dan bukan suatu pilihan. Ini akan gagal jika Anda tidak mengurusnya sekarang.
Setelah itu, pasang kembali ponsel Anda dan evaluasi kembali. Selalu ganti baterai pada perangkat yang rusak karena air. Cepat atau lambat akan gagal karenanya. Selama Anda belum membersihkan papan dan mengganti baterai, semuanya hanyalah tebakan. Ingatlah bahwa kerusakan akibat air adalah masalah yang paling sulit dipecahkan dan diperbaiki. Tidak masalah jika terkena selama 2 detik atau 2 jam, yang penting adalah dimana air (partikulat) yang menyebabkan kerusakan.
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 20
За всё время: 20
