Joysticks keep Drifting *both left and right
Hi! I own a PS4 and recently during games my view screen has been moving around as if I'm moving the left joystick, and sometimes my character even walks on its own (as if I'm using the right joystick). I notice this happens more often when I have my headphones plugged in, so I figured it could be some mixing signals? Does anyone know how to fix this ?
Thank you!
Это хороший вопрос?
Оценка 5
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
Hi Laslus!
Drifting joysticks can be solved by replacing them. You probably need to open it up and replace them both.
This requires soldering…
Also check if the replacement joysticks will match your original ones first.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
hi pls for this controller can i use analog of ps4 or ps5 to replace them?
из
Hi! Not sure.. they probably do fit, but not sure about it..
из
My game console analog is drifting right and left
Оценка 0
1 Комментарий:
Then they both need a replacement!
из
Добавьте свой ответ
Laslus будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 4
За последние 7 дней: 84
За последние 30 дней: 128
За всё время: 806
