HDMI torn from board and damaged traces
I acquired a ps5 that had a claim of a bent hdmi port, but was definitely more than that. Hdmi port was broken off the board and the many of the pads and traces are damaged or missing. I was going to try and run new traces but I'm, 1 not sure if it's too far gone and 2 was wondering if the routing on the board is the same on both versions of the motherboard EDM-010 And EDM-033. here on ifixit you can see the EDM010 BUT NOT 033
Это хороший вопрос?
2 Комментариев
Not a slim, and having a he'll of a time removing all that solder
из Rob G
@rguilmette1977 hmm, it’s probably a new revision then. Yes.. this need to be removed first before you can proceed to the repair part. Hopefully you can repair this board!
из koppie007
