Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
Why does it only work on a charger?
my psp go is not turning on and the charging light wont come on either....only when i plug the charger into it and play it will turn on ........if i remove the charger it turns back off.....help pplzzz
Это хороший вопрос?
Счет -1
Добавить комментарий
2 Ответов
Выбранное решение
jahtav, sure sounds like a bad battery. It appears like it does not hold a charge. Of course, make sure that the contacts are clean etc. Follow this guide to change your battery. You can get a new battery from here Sony PSP Go Battery as well as many other places. Once you replace the battery, and it still does not charge, you can check the fuses on your logic board. Check those for continuity with a multimeter. Hope this helps, good luck.
Replace a model LIP1412 battery compatible with the Sony PSP Go game console. Изображение
Товар
Sony PSP Go Battery
$19.99
Был ли этот ответ полезен?
Счет 2
Use the spare chager
Счет 0
Добавьте свой ответ
jahtav буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 6,767
