Repair guides, disassembly, and troubleshooting information for the second generation Sony PlayStation 5 DualSense controller. Identified by model number CFI-ZCT1W and motherboard model BDM-020.
controller turns off when the square button is pressed
everything on my controller works fine but when I press square button, it turns off the controller completely.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
The button trace is probably misaligned or dirty.
In this image, the traces for the buttons are the gold and green plastic slip that presses against the motherboard with a foam piece. Get some contact cleaner and clean off those metal contacts on the plastic and the motherboard. If this doesn't work, replace the foam padding as it eventually wears down and causes this problem.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Marcus буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 32
За последние 7 дней: 123
За последние 30 дней: 146
За всё время: 334
