Информация по ремонту и руководства для Apple iPhone 5c, представленного 10 сентября 2013 года. Модель: A1532, A1456
Is this logic board from an iPhone 5c to rusty to recover?
I just found my old iPhone 5c and noticed it wasn’t working possibly due to water damage a few years ago. I was able to get the motherboard or logic board out after a little bit of tweaking and I was hoping to get somebody’s insight and knowledged to know if this is too rusty to continue. I was planning on just swapping it out and placing it into another iPhone 5c.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
since it has been sitting for a few years then the corrosion could have caused more damage over time, only way to know is to try it with a good screen, battery and power button
Был ли этот ответ полезен?
Счет 1
3 Комментариев:
@coachb6185 before doing that, I would suggest at least cleaning it :-) Pop all the EMI shields off and then use this guide Ремонт iPhone после попадания жидкости and clean your board as described in step 11 and on. It was written for a 3G but all the steps are still pertinent to your board as well.
из
@oldturkey03 you need hot air to remove those shields
из
@tech_ni you are right of course. I'd still feel a lot better to clean it first ;-) @coachb6185 follow the advice given by @tech_ni to work on your board.
из
Добавьте свой ответ
Coach B буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 18
За всё время: 273
