{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
MBP doesn't recognize power supply
Hi,
I'm new here and haven't posted anything so far. I really hope someone can help me to figure out what the most probable cause for the fault is.
When I plug in the USB-C cable (in any if the 4 ports), none recognizes power supply.
The power supply / charging adapter is working fine on my other mbp. So it's not the cable or charging adapter.
I bought this mbp as refurbished and it came with a 3rd party charger. Recently the charger got really warm and since that day charging became more and more problematic. It sometimes worked in the beginning but now it's not working at all. Is there such thing as slow dying circuits. I am assuming the charging circuit on the logic board has a problem and was damaged by the 3rd party charger.
Is there a fix for this? Do I have to replace the complete logic board?
If anyone can help it will be highly appreciated.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
if you can buy a usbc amp meter like the 1 in the link, it will show what voltage and current its taking if any.
https://www.amazon.co.uk/YOJOCK-Voltmete...
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Axel Voss буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 9
За последние 30 дней: 36
За всё время: 168
