The HP Pavilion dv4000 laptop (model number: EC681AV) was released in March 2005. It runs on the Windows XP operating system.
HDD yerine SSD takabilirmiyim?
Hello, I am using an HP Pavilion DV4000 laptop, but it lags even while watching YouTube. I use 1gb and 256mb ram, the processor is Intel pentium 1.67ghz HDD, it is very slow and that's why I want to install an SSD instead of HDD. Is it possible to replace these parts? Which components do it support the most?
Это хороший вопрос?
Счет 0
1 Комментарий
So, which processor does the motherboard support the most? 32 bit, 64 bit? Does it support i5 3210M or i5 3470? Note:DDR2 Motherboard
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi Furkan,
Based on what i've seen online, it's likely possible for you to replace your HDD with a SATA SSD. I would recommend the Samsung 870 evo SSD or above, depending on your needs for capacity and speed.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Furkan Ali Şahintürk буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 127
