Can you test the ear speaker without service?
I recently replaced my ear speaker for iPhone 4 at&t but do NOT have service or a working sim card to make a test call... Is it possible to test the speaker another way?
Это хороший вопрос?
Это хороший вопрос?
Use stock iPhone App called Voice Memos. Make a 15-20 second memo. Then play the memo, tapping the Speaker button you can test the Earpiece Speaker.
Был ли этот ответ полезен?
thanks! good info
thanks,, it was helpful
get a Tango ,skype or Viber or any slimier app and try to call your friend who has the same app and you should be able to talk to your friend
note : you need an internet connection to do that
Another solution: Voice Control on the iPhone 4. Even without a SIM or AT&T service, if you say something into the microphone, the voice will respond through the earpiece to say "no match found" or another message. Hold the home button down until the Voice Control screen appears and then say a command.
За последние 24часов: 2
За последние 7 дней: 16
За последние 30 дней: 66
За всё время: 100,051
2 Комментариев
easier test ... use dictafoon to record something and play it, it plays standard from the ear speaker
из svenverhaegen
Actually, you can use the stock voice memo app to test the earpiece. Just turn off the speakerphone.
из E West
