BeagleBone Black — это модель BeagleBoard, представленная в 2013 году
Power light on then immediately off
Checking across most capacitors (like C2) reads almost shorted so I assume a component has failed. Short appears across the whole board so I assume a main power rail short and once the power regulator sees the short on the output it shuts down. Anyone have any guesses on which component(s) may have failed. I have 2 BBB with the same exact issue.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
In my opinion, your BBB may have a broken power management chip or some shorted diodes. If all shorts disappeared after removing power chip, the power management chip must have a problem.
If not, other components(or both them and chip) have problems.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Techni Plex буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 29
За все время: 344
