Информация по ремонту и разборке смартфона Samsung Galaxy S21 5G на базе Android, включая модель SM-G991U.
WI-FI constantly turning itself off
Okay so I got this phone second hand, it is the Galaxy S21 FE 5g, the wifi constantly turns itself off after about 10-15 minutes on the new ui 6 update, i’ve been through all settings involving samsungs smart connect, and factory reset multiple times. no cracks or outside damage. the bluetooth is fine so I know it’s wifi specific and happens on every network. it’s not my main phone but I would like to invest a little into fixing it, I just don’t know what i’d need to replace or if samsung is still as repairable as it used to be, i’ve had an iphone as my main for quite a while now
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Check for any battery saver settings being turned on... it might be that it's turning off the wifi to conserve power.
Был ли этот ответ полезен?
Счет 1
4 Комментариев:
Did you figure it out ? Mine is doing the same
из
I changed the power saving to high performance and it fixed the same issue I was having with the wifi turning off
из
I'm having the same issue
из
Same issue, and non of the solutions work.
из
Samsung has tech support for that. Not the sharpest knife in the world, but it is free and they can log onto your phone and look at it.
That is your best option.
Счет 0
Добавьте свой ответ
dominick giovannelli буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 12
За последние 30 дней: 46
За всё время: 1,533
