Samsung LCD use on LG Revision machine
Hello all I have received a replacement LCD for my Surface pro 4, unfortunately I was sent a Samsung version and it turns out I had LG version. My question is can I order a Samsung 25 pin screen connector and still use the Samsung screen I have been sent? Thank you in advance.
Это хороший вопрос?
Счет 0
2 Комментариев:
@davidking33706 where did you order the LCD from?
из
Hello good morning I ordered via alliexpress where I get many spare parts from I just want to know if I order the correct ribbon cable can I fit it to my surface pro4 if not I can return the screen thank you
из
Добавить комментарий
