1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142вопросов Показать все
Possible to upgrade Interconnect Board?
Wondering if it is possible to upgrade the interconnect board with one from a newer model? I saw this question asked once before but with an unsatisfactory answer...
And if it IS possible and i could thereby lose the Pata connection from the optical drive and gain a Sata connection would this sata connection still be limited in speed (ATA100 speeds)?
Thanks in advance!!
Это хороший вопрос?
Оценка -1
1 Комментарий
What are you trying to accomplish?
из
Добавить комментарий
1 ответ
Выбранное решение
According to this vendor they all use the same interconnect board.
If this Answer is helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Thanks!! Apparently I need to work on my googling skills..... I missed that one. And what i'm trying to accomplish is adding more storage but making it easy for myself with regards to connectors and what not. And general interest as well because I like fidgeting with the thing :-)
из
You can go that way or a self-powered USB Hub will connect many devices.
из
Добавьте свой ответ
Nico будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 504
