My Laptop doesn’t even turn on when connected to power
Okay, so I noticed the model of nitro 5 I had did not have a page dedicated to it, so I decided to make one.
Onto my laptop. I was using it normally and all of sudden everything just went black. I didn’t shake it or anything, although it’s worth mentioned that it has blue screened a ton in the past thanks to dropping it a few times.
After it goes black I quickly check whether the charging light is on, it isn’t. It seems like it’s fully bricked. I tried turning it on a ton no response and no lights for that matter. I thought it was a socket issue, changed it and still no avail. I removed the charger and tried starting it, there was no use. I tried almost everything that was there in the online help guides nothing worked. It definitely should be a hardware issue.
I even tried waiting for several hours with the laptop unplugged from the charger, still no light or anything for that matter. Looks like it’s been fully bricked. I can’t identify the issue either. Does any parts have to be replaced?
Это хороший вопрос?
Did you find out what happened
из Aa Bb
