HDMI port is not working
My laptop's HDMI port seems loose. Whenever I adjust the monitor, the connection flickers or cuts out. Initially, I could find a position that held the connection stable, but recently it's become much worse.
I opened the laptop to inspect the port for damage, but couldn't identify the specific issue. Unfortunately, ASUS service centers in India seem unable to replace just the HDMI port, and instead want to replace the entire motherboard.
Here's what I'm wondering:
- HDMI Port Replacement: Is it possible to solder a new HDMI port onto the motherboard even if ASUS doesn't offer this service? Are there resources available that could guide me through this process? (Note: Soldering requires advanced electronics skills and equipment. It's a risky option for someone without experience.)
- Display Converter: Can I use a converter like an LCD to HDMI adapter to bypass the faulty port? This would involve connecting the converter to the laptop's internal display cable and then plugging the monitor into the converter's HDMI output. Are there any reliable converters that wouldn't compromise the resolution or refresh rate for gaming?
While I saw USB-to-HDMI adapters, reviews suggest they have limitations on resolution and refresh rate, making them unsuitable for gaming.
Since your laptop is older and you're considering a new PC anyway, replacing the motherboard might not be the most economical solution. Finding a reliable converter could be a more cost-effective option for extending the life of your laptop until you build a new PC.
Это хороший вопрос?
