Представленный 3-его марта 20 17 г. Nintendo Switch- это портативная приставка, способная устанавливаться в док-станцию и выводить картинку на TV
LCD Digitizer Not Working
I followed the Ifixit guide in replacing the digitizer on my switch and after replacing, the touch does not work in general. I'm assuming that the part is faulty?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi Silver!
Could be that the replacement part is faulty OR the cable is not connected properly or damaged.
Anyway, the part need to be replaced again, most likely.. if you can share some pictures with us, that would be great!
What was the original digitzer issue?
Have a nice day!
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Hi koppie,
I would assume the replacement part is faulty. Before properly adhering it back on, I had plugged in the cables to make sure they work, but the replacement screen didn't while the original did. Unfortunately I can't provide any pictures without disassembling the switch again since my oled digitizer was scratched the the point where the lcd was visible. I guess it's time to get another part replacement!
из
Hi Silver!
Yeah, you probably need another replacement part to get it fixed!
Hopefully you will get it fixed again! If not, please let us know so we can help you further :)!
Good luck Silver! Have a nice day!
из
Добавьте свой ответ
Silver буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 86
