Repair guides and support for wired or wireless devices that provide internet connectivity.
Why my router is suddenly stopped
Plz forgive my English
I'll try to drive the point
I have a problem with my router, it's working but suddenly every five or ten minutes stop working and restart automatically i mean that all LEDs in router include the power lamp turn off and then start again, also another problem in it that all lamps are on but is not blinking not moving and then restart again. Even during write this article it's happened, i really hope that u understood my issue and passed on one of u readers
Forgive me mistakes if i used wrong vocabularies.
Это хороший вопрос?
Счет 0
1 Комментарий
Hi @abdallahma34142
What is the make and model number of the router?
Have you tried trying a different compatible, known working power adapter that connects to the router?
Have you tired connecting to a different wall power outlet?
из
Добавить комментарий
1 ответ
Выбранное решение
That's frustrating! Let's troubleshoot:
1. Power cycle: Turn the router off, wait 30 seconds, and turn it back on.
2. Check the power cord and plug for damage or issues.
3. Ensure all cables (Internet, Ethernet, etc.) are securely connected.
4. Restart your modem (if separate) and then the router.
5. Check for firmware updates and install the latest version.
6. Reset the router to its default settings (check the manufacturer's instructions).
7. Check for physical obstructions or interference from nearby devices.
8. If you've recently changed settings, try reverting to previous configurations.
9. If none of the above works, the router might be faulty (consider contacting the manufacturer or a repair service).
Hope this helps you get back online!
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Abdallah Mahmoud (Abdo) буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 103
