This Power Mac G4 has Mirrored Drive Doors.
80вопросов Показать все
Вопрос закрыт
I have a problem whit Mac os x 10.4 install.
Before finishing the installation it throws a message that he says that I provoke a problem during the installation. I did reset to the NVRAM, alone after-taste the memory RAM of factory, made it run in sure way and throw a mistake like this: RELEASE_PPC, i remove the RAM that is not of factory and now it throws a mistake of installation that says something as:
BootFatalError-cpio read error: bad file format
Install failed: algunos archivos de essentials pueden no estar bien escritos
thank you for the help. Ronny.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
The cpio is usually found with UNIX. Are you trying to install 10.6?
Был ли этот ответ полезен?
Оценка 3
I try not even to another system disk, to check that I have in the install no problem, it may be the disc? may be the battery of logic board?, reset PMU have not, thanks for your help
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 543
