Repair guides, disassembly information, support, and troubleshooting for Corsair gaming headsets.
Вопросов 20 Показать все
Audio only playing in one side of headset.
I have a wired pair of HS60 Corsair headphones. Recently the audio started only coming through on the right side of the headset. It is definitely a hardware issue. Other headphones, both wired and wireless, do perfectly fine. The same headphones also have the same problems across multiple computers. I have taken the ear cups off and pulled the driver from the left side to inspect for a loose wire connection to the driver, but everything looks good and wiggling the wires never makes the audio come back. I also have massaged the cord going from the headset to the pc to see if there was a short I could find in it, but the audio never came back that way either.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
@venom4004 check the jack. The connector (TRRS) tip, should be the left audio. Next one (Ring) will be right audio. 3rd one (Ring) is commonly ground and the last one (sleeve) is commonly the mic. Use a multimeter and check the wire for continuity from the jack to the speakers. That way you will know that the wires are still connecting in the jack. If not, then it is time to replace the jack. If you have never done this and need help with that, just let us know.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I think you are right about it being the jack. I was able to unplug the jack slightly and get it in the perfect spot where it plays through both ears. I have never replaced it before but I'm going to take a crack at it. I already have gotten a replacement for the headset, so this is more of an attempt to fix it for the fun of it/having a backup pair.
из
Добавьте свой ответ
VeNoM4004 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 8
За последние 30 дней: 33
За всё время: 217
