The Power Macintosh G4 is series of personal desktop computers released by Apple in 1999, and sold through 2004. This page is for the M5183 designation.
39вопросов Показать все
How to extract and read the internal hard drive
Hey everyone This is my first posting hope anyone in Ifixit community can help me....I have an old Power Mac G4 that is not working- motherboard is fried... but I would like to try and remove/Extract and read the internal Hard drive on some other divice ..... Please help....
Thanks,
Pixelfreak
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Выбранное решение
First remove the IDE ribbon cable, then the power cable. There's a very small phillips screw holding the hard drive bracket in place in the center front of the bracket under the ribbon cable that has to come out. Then pull the drive out horizontally about 1/2" to dis engage the slots holding the drive in place and lift out. Next you need something to put the drive into such as an external IDE enclosure or a Universal Adapter. This one can be used for different types of drive and is very handy, it connect via USB: Universal Drive Adapter
Update
I got my Universal Drive Adapter everything works .... just one problem....the hard drive I want to download does not load to my desktop ... I hear the hard drive spinning but for some reason does not load....
please help...
Thanks
Universal Drive Adapter Изображение
Продукт
$24.99
Был ли этот ответ полезен?
Оценка 4
3 Комментариев:
Thanks Mayer, I will give it a shot!
из
First, from the desktop, go under Finder to preferences and see if you have checked the see external drives. Next go to Applications > Utilities > Disk Utility and see if the drive is seen in the left hand column and if you can repair it.
из
Why do you think the logic board is fried?
из
Will it extract info from windows drives? XP?
Оценка 0
Добавьте свой ответ
Pixelfreak будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 3,040
