Media players with CD read capabilities
Panasonic SL-SV500 Portable cd player makes scraping noises
My panasonic cd player makes a weird scraping noise when i play cds. It works fine but the sound bothers me. The sound goes away when i hold the player sideways and it comes back when i put it down. Is there anything i can do to reduce the noise?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
If it’s a top loader it could be in some cases the disc rubbing on the back part of the lid or base. To test that theory you’ll need to stick something in the hole the lid clips into and spin a disc up with the lid open. If it no longer makes the noise then it’s probably a manufacturing defect.
Although not a common issue not unheard of either. The fix for that is to figure where it’s rubbing and grind or sand down the plastic
If it isn’t that it’s probably the mechanism needs a good service, or replacing Something I haven’t done.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Skyer0cks буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 11
За всё время: 124
