Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544вопросов Показать все
Can I replace a cracked matte screen with glossy glass from iFixit?
I've got a MacBook Pro 17" Unibody early 2009 and during recent repairs* I accidentally cracked the screen. The LCD seems fine, no rainbows or what have you, but the surface is cracked. I've got the matte display with the silver bezel, and was wondering if I could replace the matte glass only with this: [связанный продукт отсутствует или отключен: IF162-000]
Second, I assume that if the repair is possible, that the part in question is the usual glossy glass, meaning the display would no longer be matte? Also, if I do the repair, do I need any other parts, such as a bezel for the glossy glass etc?
*the repairs aren't relevant as such, but still a pain; a blown right fan caused battery overheating, causing battery swelling, which destroyed the trackpad (situated right above the battery) as well... $350 in parts and a few hours of labour just because one bloody fan blew...
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Sorta kinda... theLCD itself can be glossy or anti-glare, so keeping the matte LCD is good news, as it appears to be the actual difference between displays, providing that you don't damage the bezel, as you change the glass. I guess it can be a PITA if you need to find a bezel.
If this Answer is helpful please remember to return and mark it Accepted.
MacBook Pro 17" Unibody LCD Panel Изображение
Продукт
$149.99
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Thank you for the information!
My bezel is undamaged, the only damage to the screen is a small crack in the glass. So I'll just order the glass and replace it.
из
Remember to order new tape - You can't reuse the OEM stuff once you pull the old glass off.
из
Добавьте свой ответ
Juho Varumo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 2,932
