The Toshiba Satellite S55t-C5225 is a laptop with a 15.6-inch size touch screen and an Intel i7 processor. Part number is PSPTQU-00U01C and model number is S55T-C5225.
Вопросов 1 Показать все
My Bluetooth range is short
To connect devices to my PC via Bluetooth it doesn't connect unless if I did put the device in the PC, what shall I do?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
I believe the Wi-fi and Bluetooth are on the same card so you might be able to upgrade it???
  • But it is more likely that one of the two antenna wires connected for the Bluetooth has come off. Have you been inside the case lately or bumped the computer hard?
  • The Auxiliary antenna terminal on the wifi card provides Bluetooth reception but without the second antenna wire connected, there isn't enough or hardly enough signal strength for the Bluetooth to connect to anything, like you are saying.
  • Take a look inside to see if they are all connected. Click below for the guide on how to open the case.
  • How to open case
Unfortunately I don't know where the Wifi/Bluetooth card is on this model. On some models the card is under one of the ribbon cable. Look for shiny brass right angled "dome" connectors. Normally there are three of them but . . . ?
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
robelmulatu36 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 16
