The SVE15112FXS model was released by Sony in 2012 and operates using Windows 7. This E Series laptop is designed for work, school, or leisure.
Why my PC is running very slow?
Why my PC does not work fast ?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Well I will suggest you to use a good PC cleaner software to remove the junk and unwanted files and folder form your system as well hidden junk as well which is very hard to remove manually so for that you can try the software called Advanced System Optimizer or CCleaner are two good option to try. And also Update the windows to its latest version.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Shampa Dutta буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 97
