Phone washed, after drying wont run on battery.
Will getting wet ruin the battery?
Phone went through complete wash/rinse cycle, found when moving clothes to dryer. I took out SIM and battery, blotted dry and set it in front of a fan for two days. The fan was not a hard blow just a good bit of air movement.
Put it back together and plugged it in to wall charger. Phone booted to lock screen saying it needed to be activated. I unlock it and it has the usb cable plug me in graphic. But it keeps rebooting shortly after getting to lock screen (about 20 seconds).
If I disconnect from power it shuts off like batter is dead and will not do anything without being plugged in.
It will not boot to lock screen plugged into USB only wall outlet. USB gets the Apple logo a bit then turns off then repeats.
Home, power and screen all work fine.
Kinda seems to be in DFU mode like OS install is hosed.
Это хороший вопрос?
2 Комментариев
Thanks for the info, even on a Sunday! I have it apart and back in front of the fan for a couple more days. I will replace the battery after cleaning it all and see how it goes.
из Mark Pence
hi my phone got liquid damaged back in novemeber 2014 and now i can still plug in and it sits at apples logo then shortly turns off and when i unplug the power cord it doesnt work at all now i want to know if i replace battery will it boot up or am i screwed because it still shows boot logo without water marks on screen or any clear signs of damage
из joshuafitzgerald
