What does the F41 code mean on a Kenmore Oasis Elite dryer
What does the code F41 mean on my dryer?
Это хороший вопрос?
Это хороший вопрос?
My dryer (Kenmore Elite Oasis Canyon) also had the same error code flashing F 41. After dismantling and troubleshooting, the problem was in the blower motor. The problem was a baby sock had made it past the lint screen and got hung up in the impelor of the blower assembly. no parts needed replaced, just removed sock, put everything back together, dryer is working fine. just thought i'd add my experience to hopefully help out the next guy.
Был ли этот ответ полезен?
I had the same problem. One of the face masks slid through the lint screen and in to the blower fan. I had to disassemble the front and feel my way to the blower fan to pull it out. Your answer helped me fix it! Thanks!
How did you disassemble? From the front or back?
Deedee, "the "F41" flashes when there is Blower Motor failure or if the fuse in the circuit between the machine control board and the motor control board failed . The inline fuse in located in the blue wire between the P9-1 connector and L1 on the motor control board. Diagrams for your dryer are available right here. Hope this helps, good luck.
За последние 24часов: 6
За последние 7 дней: 18
За последние 30 дней: 45
За всё время: 12,651
1 Комментарий
Kenmore elite oasis dryer reading f41 thanks
из Jeff riden
