The Xiaomi Redmi Note 10 Pro is a mid-range smartphone by Xiaomi released March 2021. It has a 6.67" AMOLED display, a 108 MP main camera, a side-mounted fingerprint sensor, a 5020 mAh battery, and runs on a Snapdragon 732G.
Can I replace menory to new device
Hello. I have waterdamaged redmi note 10 pro. Can i replace a memory in new same with old flash? Can i replace only flash or i have to flash and CPU? I was desolder flash from broken phone. I need back my data :/. Thanks for help
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
@dominikbor88826 you can't. Those parts are all "married" to each other. The only way you get your files back is by fixing it to the point that your phone comes on long enough to back the files up.
You are not telling us how old the water damage is and what you have already done to fix it. There are repairers out there that have specialized in retrieving data from water damaged devices. Their skills cost and none of them to it cheaply.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Dominik Borysewicz буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 55
