How to repair a crankshaft
I have a crankshaft problem. Can it be repaired
Это хороший вопрос?
Счет 0
2 Комментариев:
You’ll need to give us a bit more.
Why do you think the crank shaft is the issue vs the spark timing, the valve lifters or the valves/seats or even the cylinder rings or the cylinder piston or connecting rod.
из
@magd13871 what year is your Citroen and what engine does it have? What are the issues with it and what have you checked?
из
Добавить комментарий
