Delonghi ESAM4200S stuck on red triangle when power on
Hello, I have a Delonghi ESAM4200s with the red triangle led that lights up and stays on when I switch on. (Sometimes, 1 cup and 2 cups leds are on too).
I used the test mode (press and hold 1 cup + steam and switch on), everything worked perfectly except the thermoblock. No led turns on when I pushed the « Rinse » button, it doesn't heat up. So I checked its resistance and it was good (38ohms). The thermofuses are good too. The thermosensor is good too (10kohms). I tried replacing the power supply board and nothing changed. I checked the all switches and all works fine.
Do you have any advice on what I should check?
Это хороший вопрос?
2 Комментариев
@dylanbeaucamp let's see if our coffeemaker guru @vauweh can help you out with this.
из oldturkey03
Thank you for your help
из Dylan Beaucamp
