The Xbox Elite Wireless Controller Series 2 was released on November 4, 2019, and is compatible with the Xbox One, X, & S consoles as well as PCs running Windows 10/11. Model 1797.
Controller turns on but will not work
So basically i took my controller apart to repair something, when i plugged it back in, its light lit up, which means the power supply is working fine. However it wont respond to any button pressing. Also, when i plug it into my pc it shows that a device is connected but in the Xbox Accessories app, it wont show a connection. The cable that connects to the motherboard might have a Problem, but i am not sure. Does anyone know a fix?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi there!
First I would advise to get the motherboard out and clean everything. Replace the button pads if needed. It's possible that something on the motherboard died, but let's try this first.
If this failed, then you do need to measure some things on the motherboard.
Please let us know how it goes!
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
LennK буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 107
