Where is the actual power ic? - Solved
i have had this similar problem, it took alot to repair though, i replaced the battery, charging dock and i reflowed the board, this worked for me, and where is the actual power ic?
Это хороший вопрос?
Это хороший вопрос?
Step 17 of this guide looks straight at the IC. It is labeled 338S0867.
Был ли этот ответ полезен?
If you actually do need to replace this I.C. the cheapest place to buy a replacement from would be here.
Power Supply IC Chip For iPhone 4
Unless you are trained in replacing an I.C. I would recommend asking Hector Hector's Profile
He is a Guru at soldering.
thank you too deano, your help was much appreciated, thanks again my friend
За последние 24часов: 2
За последние 7 дней: 12
За последние 30 дней: 19
За всё время: 13,043
1 Комментарий
thank you alot, my friend, you are awesome, thanks to you got the repair done with and the customer was extremly pleased, thanks again
из Krayzee
