Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212вопросов Показать все
Вопрос закрыт
iMac black screen after 2 to 3 seconds of start up
i start my mac i got the white screen but after 2 to 3 seconds the screen turns black , fan is working , led # 1,2,3 are all on dvd stuck in the drive won't come out , i can hear it spinning.
already tried pressing start and holding the shift or the option button, zapped the pram too , still nothing
installation disk from my macbook is stuck in the drive , also tried holding the C at while starting. HELP PLEASE
Это хороший вопрос?
Оценка 0
5 Комментариев
model is A1207
из
Press and hold the MOUSE or the SPACE BAR on startup.
из
alright 2 good things did happened the disk is out , i pressed hold eject from start up and the disk came out.
second i pressed and hold option from start up and the screen did not went black this time , but now i have a white blank screen with only the cursor(black arrow) which i can move around. but thats all.
what should i do next to get it to start and work normally now ?
by the way thanks for the help
из
new development i shut it down and again i hear the chime the front light comes on and dimmed slowly off after 2 to 3 seconds and my screen goes black , if i press and hold the command button at start up the screen remains grey and after a couple of minutes a folder with a question mark will start flashing on the grey screen. ANY SUGGESSTION WHAT I SHOULD DO ?
из
Hi laman,
could you tell me what the problem was and what you did to fix it. I have the same issue with my imac 2009.
Christian
из
Добавить комментарий
3 Ответов
Выбранное решение
I had a messed up windows install disk one time stuck in my drive and it caused this, try holding eject from power up, this may force the disk to eject. also if u can get to the firmware there is an eject command that force ejects disks.
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
Your computer cannot find a valid startup folder. Either your system is corrupt or your hard drive has failed. Try starting up from your original system installation disk by inserting the disk and restarting holding down the "C" key. Go to the second screen pull down menu to Utilities > Disk Utilities. See if your drive shows up in the left hand column. If so click on it and see if you can repair it. If not the hard drive will need to be replaced. Let us know your results and we can proceed. I also can't tell if you have an iMac or MacBook. Please give us the last three figures of your serial number so we are both on the same page.
Оценка 5
2 Комментариев:
okay i'll try that Mr. Mayer.
its an IMac(Intel) model A1207 i have to search for the original system installation disk , i own a macbook too. insert the disk number 1 into the iMac drives and hold "C" while starting but nothing happens . i'll go now and try again. if nothing happens i'll have to search for the iMac original system disk.
i'll brief you back as soon as something new comes up.
thank you Mr. Mayer
из
I have the M A1207 model too...my died like this a year 2 years ago. Every once and a while I'll try turning it on following all the ideotic suggestions like hold down shift, hold down space bar, hold down letter d on start up ... noting works. What a joke. My computer came pre-set up so there is no disks to try...nothing.
Fustrated as it died after the 3 year warranty had expired. What a waste of $1500 for a better product
из
Fustrated as it died after the 3 year warranty had expired. What a waste of $1500 for a better product.
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 9,097
