Tecno Spark 6 Air mobile was launched on 30th July 2020. The phone comes with a 7.00-inch touchscreen display offering a resolution of 720x1640 pixels and an aspect ratio of 20.5:9. Tecno Spark 6 Air is powered by a quad-core MediaTek Helio A22 (MT6761) processor. It comes with 2GB of RAM. The Tecno Spark 6 Air runs Android 10 and is powered by a 6000mAh battery.
Why my phone is not connect with PC using wire?
I want connect it with PC using cable or wire
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Is the phone receiving power but not data, or is it not receiving power at all? I would try verifying that the cable works by checking to see if the cable works with other devices, or if trying to use another cable resolves the issue. If the cable transmits power but not data, it may be a power-only cable, which means the issue can be solved by using a cable that supports data transfer.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
AAziz буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 50
