The second generation of Scion's box-shaped hatchback.
Why is my window washer only squirting on the rear window
why is my window washer only squirting on the rear window. what needs to be replaced?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
@unclegabe that all will depend on what you have checked. This could be an issue with the washer fluid motor, connector to the water tank. Check your fuses. You also want to rule out that it is a clogged line and clogged spray nozzles. Disconnect the hose that leads to the jets. Then try and if your have water coming out of that hose, it is your nozzles.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Uncle Gabe буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 66
