1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
My Mac Mini does not respond when connected to a display.
May I ask how to solve the problem of my Mac Mini A1176 having a power on response, but no response when connected to the monitor despite the power light on
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Did you try testing with a second display or double check the display connecting to another system?
While the systems LED may be lit, did you get the startup Bong sound?
This system requires a button battery to hold its settings (PRAM) have you tried replacing it? Mac mini Model A1176 PRAM Battery Replacement
With the cover off do you see any leakage around the electrolytic capacitors on the main logic board?
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Thank you, friend. I have tried to replace the motherboard battery and monitor, but there is still no image display. When starting the machine, there is a sound of the optical drive and hard drive starting, but there is no system startup sound as you said. Do you think it is a problem with the motherboard
из
@uxq7rnbz1tzbxsp - Do you still have the CD/DVD the system came with? One should be marked as a bootable disk see if you can get it to boot.
из
Добавьте свой ответ
中国缪缪 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 90
