Why is blender jar making noise and leaking drops
Why is the blender jar making noise and leaking drops
Это хороший вопрос?
Счет 0
1 Комментарий:
Why is my car making noise and leaking drops????
No one can give me a good answer.
Maybe you could do better with your question, ya think?
из
Добавить комментарий
1 ответ
The sound you hear could be the bearings in your blade assembly in the container going bad. With the leaking in addition, you may want to invest in a new container. The worn out bearings in your blade assembly may have caused the assembly to move during use and worn the plastic causing the hole at the bottom to widen. When you get the new container replace your drive socket too.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
zakayo chacha буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 143
