mouse pad is not working properly
mouse pad having problem suddenly when i hover on mousepad cursor wiggles badly and was unable to make a correct point
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
@princemittal check to see if this is a possible driver issue. I would uninstall the current driver and then reinstall the latest driver for it. If that still doesn't work, you may have a bad touchpad. If you let us know what version your OS is, we can try and assist you further with that as well.
To work on your physical touchpad use the HP 15s Eq0000 Maintenance And Service Guide Page 36 shows you how to work on the touchpad.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
prince mittal будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 11
