Apple's smallest iPhone 14 was released on September 9th and comes with a 6.1" OLED display, an advanced dual 12 MP camera system, and a front camera with autofocus. Successor to the iPhone 13.
Won’t shift to full screen when turned
Suddenly, the screen will not shift to full-screen mode when turned horizontally for picture or video viewing. It used to do this. I can’t find any such control reference in settings. Any suggestions?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hey, @donrimmer
Check to make sure that rotation lock isn’t engaged. Rotation lock setting is accessible through Control Center which you can access by swiping down from the right top corner of your screen. The icon for rotation lock looks like a clockwise pointing circular arrow around a lock. If you don’t see it you may have to add the option of Rotation Lock to your control center. This process is differs slightly depending on whether or not you are running iOS 18. If you are running 18, simply open Control Center, click and hold in any blank area on the screen (not occupied by a button) and then it will say “add control”. Click this and search for Rotation Lock”.
If you are running iOS 17 or lower, simply head into Settings > Control Center > scroll down and find the Rotation Lock option and click the green plus to the left of it. It will now appear in Control Center and you should be able to turn it off.
Keep me posted,
Cheers!
-m
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Don Rimmer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 8
За последние 30 дней: 52
За всё время: 288
