Released in 2008, the Sony Walkman NWZ-E436F is a portable media player with a 2-inch screen. It can play audio and video and has a built-in FM radio tuner.
11вопросов Показать все
Sony Walkman NWZ-E436F went thru washer can't open it to dry
I removed the two screws on the back but still can't open it up- Help!
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Выбранное решение
Judy, get the service manual from here . You will see that it has clips the holds the both halves together You can try to open it with the iPod opening tools. Once open, use this guide to clean your Walkman. Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 1
Mine is a japanese item but i don't know japanese at all.please help me use it.thank you very much !
Оценка 0
2 Комментариев:
Have you tried the service manual from the above link? what have you tried so far?
из
I'm reading it
из
Добавьте свой ответ
Judy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 2,177
