Missing capacitor, and boardview doesn't help
So I have this 820-00928-A board (A1707 - 2017) with a missing capacitor, just under the right speaker connector. The problem is, all brd's I've found show this area exactly like the 820-00281. Too bad they're different!
The first picture shows what can be seen on the brd file, both 00281 and 00928.
Picture two shows the actual 820-00928 area I'm interested in
Picture three shows the same area with the blown component.
Can anyone please tell me the values of the blown capacitor, so I can look for the same part on a different board and replace it?
Thank you in advance for any help.
EDIT - I guess it should be 22UF - 20% - 10V - X5R-CERM - 0603-1, as per components C9310, C9311, C9312 and C9313. Four identical components, same size even though the positioning is different. Can anyone confirm?
Это хороший вопрос?
3 Комментариев
@mafomo that's what I show. Go for it. Order a couple and replace it. Let us know how it works out.
из oldturkey03
@oldturkey03 and @danj I made an appointment with a guy who has better equipment and a donor board for next Tue. I will report the result.
из Massimo Oriano
Sorry for the delay but we’ve had a bunch of holidays here. However: the missing component was not the cause of the problem. As it’s been explained to me, that capacitor had a mere “filter function”, so theoretically it would have worked even without it.
The issue was the half-dead SMC chip. Once replaced, the machine behaved as it should.
Thank you all for the kind help
из Massimo Oriano
