Broke something off the PCB
Hello!
I was trying to clean the PCB and broke a small white bit off of the S key and now it won't work.
I also lost that small white bit.
Is it something that can be fixed with soldering?
Example of the white bit that broke off in blue and where it broke off in red.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
@sergiover that is a photodiode. Use a multimeter and measure D90. That should be a direct replacement.
If you can, post some well focused close up of that part. Let's see if we can determine what type of Diode this is.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Sergio буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 77
