A HD pocket camcorder to compete with Flip mino/ultraHD. Many view the Kodak Zi8 as having a better set and a camera worth considering more then the Flip.
Why does the camera run down in ten minutes?
I charge the camera - with several new batteries - and it runs down within ten minutes. How can I fix the charging mechanism?
Это хороший вопрос?
Счет 0
1 Комментарий
I have tried four new batteries, and two new battery chargers - and also charging it from the computer.
из
Добавить комментарий
1 ответ
Выбранное решение
Because the battery in your device has aged, if possible, you can replace the camera or buy a battery to replace it
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
из
@jmartz42667 Fast power consumption solution: Turn off WIFI: WIFI function can be turned off when not in use to reduce power consumption. Adjust backlight and warm light settings: Reducing backlight and warm light can lower power consumption. Waiting for the download and indexing process to complete: After the device completes the download and indexing process, power consumption will return to normal
из
Добавьте свой ответ
jmartz буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 88
