Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2375вопросов Показать все
iPhone turns on when plugged into wall then wont hold a charge
Originally my battery went dead so i replaced it. After replacing it I plugged my iPhone into the wall charger, it turned on and eventually says Connect to iTunes. After letting it charge for a while, I disconnected the phone from the wall to plug it into iTunes. Upon disconnecting, the phone shuts off completely and wouldn't turn on. When plugged into mac it will not turn on either.
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
jonscr20, if your iPhone comes on while on an AC charger, but not on your computer, it is most likely that you have a defective battery. Also, check the dock connector for any bend, broken or corroded pins. Clean it with some isopropyl alcohol. Make sure that your USB cable is in good working order. It comes on when charged on AC because of a higher amperage that is supplied by the AC charger. Replace the battery, re-evaluate and, if it still wont work properly, replace the dock connector. Hope this helps, good Luck
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
thank you! i just ordered a new battery and ill give it a shot
из
Добавьте свой ответ
jonscr20 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 716
