1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
11" > 13" LCD Compatability for Testing ONLY
I have a 2011 MBA 13" A1369 here in perfect working condition.....I also have 2x 2011 A1370 11" that need repair but before I waste time fixing them I need to know if their LCD's are still good..... Can I connect the 11" LCD to the 13" to test? Checking this page it seems that it is OK to do so but their info isn't clear. I need 100% confirmation as I do not want more busted units laying around : We are not worried to test the WiFi or Bluetooth, ONLY to see if the LCD are OK.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
@livfe no reason why you can't do that. The LCD connector as well as the connections are identical between the A1369 and the A1370.
A1369
A1370
Был ли этот ответ полезен?
Счет 1
6 Комментариев:
Thanks for the confirmation, I was sure it was possible as I think I did this before, but just to be 100% certain before I go ahead. :)
из
@oldturkey03 One is actually a 2010 Model and has a silver connector for the LCD, other are gold..... best no to try,......
из
@livfe if those boards are an 820-3023 and the other a 820-3024 then you are okay. The color of the connector really should not matter.
из
@oldturkey03 2010 - 820-2855 or 2010 - 820-2796 likely..... All I can see on the board is C02144501QUDK9LAY 1.6 GHz HY 2 GB
из
@oldturkey03 But, the A1369 A1370 2011 LCD cannot work with 2013-2017 models unless we swap the cables over correct?
из
Показать ещё 1 комментарий
Добавьте свой ответ
livfe буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 98
