check lent filter light on and will only run on express dry
My Kenmore Elite Dryer has the check lint filter light on and will only run on the express dry cycle, I cleaned the lint out of the lint trap area and vacuumed the rest of the area, the dryer turned on on a different cycle as a test run, but when to dry the next load it went back to the express dry cycle, and check the lint filter light is back on, what more can i do as have not found a troubleshooting guide for the model i have.
Это хороший вопрос?
3 Комментариев
If you have a Save Energy button and only after you have checked filter and made sure the duct is clean, press and hold the button for 3 seconds!
из Christa Buttrill
This is the right answer. I already knew it was locked, because my washer had the same issue. All the talk about cleaning filter is wrong. You just need to hold the save energy button for 3 seconds on the dryer. The washer requires holding 2 buttons simultaneously and you can find instructions on the quick reference guide.
из hookuprt
My dryer says to check the lent trap the control board comes on but the dryer don’t work on any setting !! Help !
из pameladanneker
