Lines on screen appeared not damaged screen
Still got these lines after replacing main board. They don't go all the way across, any ideas please. Thanks.
Это хороший вопрос?
Счет 0
8 Комментариев:
Hi @briandillon1980
Did you get the exact same part number/revision number replacement mainboard as the original mainboard?
What was the original problem that made you change the mainboard?
из
Yep exact part replacement, someone on here said it could of been memory problem due to the lines not going all the way across @jayeff
из
Said to replace main board
из
@briandillon1980
If the problem is still there after replacing with the exact same mainboard this sort of confirms it's not the mainboard.
To me it looks like a gate driver problem in the panel as that's what it usually is with horizontal lines across the screen.
Basically it's non reparable unless you can find a replacement LCD screen.
из
Ok thanks for your help. New TV then.
из
Показать ещё 3 комментариев
Добавить комментарий
